Wheelbase is 105" on driver side 104" on pass side.
The car is 100% Carbon fiber, all with Mopar part numbers of course It has a LOT of aero tricks on it. From the front end overlapping the doors, the full belly pan, the trunk lid sliding under the rear of the body to the aforementioned wheelwells and some other small carbon deflectors at the rear. It is a very trick piece for sure.
Here is a shot of the rear end
You gonna put a 9 inch in it?
