Borgeson has a solution, they list it for Dodge trucks but they may custom make them
https://www.borgeson.com/xcart/popup_image.php?type=D&id=1452
would be the same than break the safety shaft plastic pins into the column shaft
Not sure what you are saying here. The Borgeson unit allows for the joint to slide in and out some.
They say there are no such thing as a stupid question. They say there is always the exception that proves the rule. Don't be the exception.
