Is this a street car, or a race car?
The Comps are a nice little rocker. The price has been driven higher and higher every year, but still a pretty nice piece. At that level, I use the Comps and Hughes rockers. Once into a full race application, then I think its best for H/S, T&D etc.
The alignment issue on Edelbrocks is just thjat. an issue. Years ago I had H/S change the roller wheel axle to better accomodate the Eddy heads.The axle simply has to be moved. The rockers were originally designed for iron heads, and even early and later version of Eddys seemed to have changed, even though they say no. So yes, unless you order H/S set up for Eddys, you'll have the issue that DJV has shown.
Again, for a non aggressive race lobe, or a street/strip type application, the Comps and Hughes have worked great....
