When you drill the block for lifter oiling like the factory does, the lifter bores will LEAK a TON compared to how we did Forest's block...not saying it's wrong, but it makes a very big difference in leakage going from factory type oiling to a metered .060 hole!
And no chance of aerating the oil with a small hole that cannot be uncovered.
Brian
Brian Hafliger
