Re: Struck out on dakota, scored this instead
[Re: feets]
#1648113
07/24/14 05:50 PM
07/24/14 05:50 PM
Posts: 380 Escondido CA USA
Tomswheels
Escondido CA USA
I respectfully disagree. Unless you like doing donuts.
Throttle modulation.
An autocross is a tight relatively low speed event. I've been around them a time or two as well.
The only way to make his car push harder than his current setup is to swap in a big front bar. That thing will not want to turn under pressure. Add a rear bar to tighten up the front end. It will bring the car back to a more neutral state. A cheap 3/4" Addco bar would add quite a bit of life to that thing.
If it starts to get a bit pushy then slide one under the front.
Sounds like you know more about Abodys and Autocross than me. Must be my stellar driving that seemingly makes the opposite true when I'm actually in one auto crossing. I have a rear bar removed from my Cuda someone can have (free) it worked so well...
Entire Thread
buconine
07/19/14 05:00 AM
amxautox
07/19/14 05:07 AM
buconine
07/19/14 05:28 AM
Jim_Lusk
07/19/14 05:46 AM
MuuMuu101
07/19/14 06:43 AM
Tomswheels
07/20/14 01:07 AM
buconine
07/20/14 02:30 AM
ScottSmith_Harms
07/20/14 02:54 AM
ahy
07/20/14 03:32 AM
buconine
07/20/14 04:09 AM
buconine
07/20/14 04:23 AM
BigBlockMopar
07/20/14 09:24 AM
Sneke_Eyez
07/20/14 06:22 PM
IndyDave
07/20/14 06:26 PM
TC@HP2
07/20/14 07:44 PM
IndyDave
07/20/14 10:32 PM
TC@HP2
07/21/14 12:52 AM
IndyDave
07/21/14 01:14 AM
TC@HP2
07/21/14 04:40 PM
72Swinger
07/20/14 09:54 PM
Tomswheels
07/20/14 03:23 AM
feets
07/21/14 07:37 PM
Tomswheels
07/22/14 04:07 AM
feets
07/22/14 06:50 PM
Tomswheels
07/24/14 09:50 PM
Skeptic
07/22/14 05:18 AM
buconine
07/25/14 04:01 AM
Pale_Roader
07/25/14 11:22 AM
Skeptic
07/26/14 01:49 AM
