On July 1st, KB said they were finishing another block and they would start machining mine on July 3. Since I ordered the lifter galleries drilled for oiling the rocker arms through the pushrods, they do some machining operations first. Then send it out for the lifter gallery machining. When it gets back to the KB shop they finish machine it including lifter bores, cylinder sleeves, final hone, etc.
