Disconnect the alt wire from the alt then flip the
master off.. see if it dies then... but your picking
up power from the alt... thats why I hook the alt wire
up to the battery side of the master.. nothing to go
wrong... just to test the master unplug the field wires
at the alt(does the same thing as un bolting the output wire
Quick reply... disconnected the wire from the alt (no longer have the relay hooked up as shown in the diagram above) did not die, kept running. Scratching head there... but again, will wait till tomorrow to pick up where I left off.... more help is always greatly appreciated. Thanks again,
Use a ohm meter and check the master to make sure
it goes open when it shut off
