Ok, thanks. I had found on one car of mine that the poly trans mount transmitted more vibration than the poly engine mounts, and the vibration was from the engine, not the transmission. First I put the rubber engine mounts back, and not much difference. But when I put the rubber trans mount back in the vibration was cut in half.
From now on, only internally balanced 360's for me, but that's a different thread.
Facts are stubborn things.
