Yes timing is set at 15 degrees initial and 33 degrees total. I have some .028 idle feed restrictors, but I only have 3. So I will put some .028 idle feed restrictors in the primary metering block and see what that does. If it helps then I will order another .028 idle feed restrictor and put them in the secondary metering block as well.
