Frank, if it truly DID move in , you might check the shaft and see if the c clip around the shaft above the small ball bearing got dislodged.You may have to remove some turn signal switch stuff to get to it to even check.
I'm 55 now, no time to waste. Not a week goes by that I don't hear about someone passing on.Let's get out there,smoke some tires,have a beer with a good friend,do what you have always wanted to do.I am pretty sure no one will ever say on their deathbed "gee I'm glad my life was calm and boring"
