There are places out there that will make the stripe. I would have to look because I did research on this (I actually owned the white one above). The stripe color I believe is not uncommon, you just need to find someone that die-cuts correct C Stripes if I remember correctly. I did talk to someone though that would do it. I will try and find the info. Its been a while.
