Thanks, Gary. I figured you knew. I don't have access to a stud gun like that. I have found some alum pop rivet stud replacements and the local auto body supply place says they can get some steel or brass pop rivet ones. I also found some screw in studs that I can use. May talk to one more body shop here in town.
