Yes, neutral balance damper , no weights on convertor except a thin flat 8G weight on the back side. Never had a problem like this, and the machine shop says the notched flex has to be used. I thought that flex was for cast crank engines. Thanks for the replies. Yes , shakes in any gear.
1971 Demon drag car
2004 SX 2.0
1971 Duster 340 4 speed , project for my Daughter
1998 Dodge Ram 3500 SLT Laramie quad cab dually 4x4 V10
