Did you install all the bows into the side clips and then try pulling tight? this may be causing to much friction and not allowing things to move properly. I have always had luck starting with hooking up the wires and then installing one bow at a time into the side clips and pulling the headliner tight each time. When you get to the front all the bows are pretty well tight and one last even pull should be all that's required to get everything to a good starting place to begin final stretching and attachment. Also one last thing I can think of is to make sure you cut enough clearance through the listing pockets where the ends of the bows come through. Not enough and it will cause the headliner to bunch up because it cannot stretch out to the sides which will contribute to the sag you are talking about as well. The bows are also place specific and should be color coded as to where they go. If they are not in the correct position you will have issues. Good luck and hope you get it installed.
I did install the bows rear to front while pulling forward, I don't think it's a friction problem. I may need to check to see if I need to cut the listings more to see if the sides are holding the center from stretching out. I currently have ~3/4"-1" of the end of each bow sticking out from the listing. I hate to cut off too much.
The bows were with the car when I bought it but it had no headliner. They appear to be original and seem to fit well but I can't be 100% positive. They weren't color coded.
Can anyone measure the distance between the seams at the center of their 6 bow headliner ('71 Plymouth B-body)? That would help me understand if I have an incorrect headliner (long shot I know).
I'll try and post a picture tonight.
Yes you have to cut the listing quit a bit to get it to fit right. Look how much wider my new one is compared to my old old. I remembered doing that after reading your last post.
