Dannysbee - thanks and I also happen to love the 62-65 B bodies. Sounds like a very cool combo you are putting together
Fullmetaljacket - Lots of uncertains, mostly in the suspension. Pretty sure the carb will be a quickfuel 950. 11.0's would work for me
Exit1965 - My cam is the exact one Andy used, I purchased it from him. He ran eddy heads I believe, but I will not expect anywhere close to 630hp.
P body - youre correct, this car is not set up to run the quarter (or the eighth for that matter). The tires are about the only thing I have going for me. Might run low 11's, or maybe low 12's doing the slip and slide!
