Been trying to find info for a friend who has the stalling after fill-up problem that has plagued earlier Hemi cars. 2005 300C. The web shows that it was a known tank problem and a limited recall was done on some cars to replace the tank. Some said they took the vacuum line that goes from the intake manifold to the purge solenoid (all under the hood) and insert in line a fuel filter that traps the fuel and then bleeds it slowly. Anyone know of this or any other "fixes" that might work without pulling the tank?
Kazi
