MegaParts has a screw/washer kit for them. They are very simple to completely pull apart, clean, glass bead the housing and paint. I've been lucky with the few I have rebuilt, the shaft bushings were still tight and didn't need to be replaced. The oiler pulls out with a little force, so that you can clean or replace it with a new one (Crossram Connection makes them new).
thanks, thats the kind of stuff i'm looking for.
what about the vacuum advance, how do i clean that up?
