Quote: Good old fashioned cheap build A set of 1.88 intake heads off a 360
Drops the compression too much, been there and done it.
me too, but the right cam makes up for the low comp ratio
like the whiplash roller cam I stuck in my 91 318, it has short duration/high lift/early intake closing/tight LSA to build cyl pressure and not bleed off torque.
then add a loose TC and some gear the lopo 318 will get with the program.
but it is at a street engine level not a racing engine level of performance.
performance above street level is more $$$ and not so cheap.
