A 1/2" conduit punch makes a 7/8" hole. That is too large so be sure and do homework before cutting. I am away from my car and not able to send any detailed info. Good Luck.
The 7/8" hole is just what I measured on my bare Cuda hood, so that conduit knock out would do the trick, the pin hole location is: measuring from the SIDE edges of the hood, 4 1/4" from the DRIVER"S/PASSENGER"S SIDE edge to the center of the pin hole, and 3 1/4" from the front edge of the hood to the center of the hole, the smaller bezel/screw holes can be located by centering the hood pin bezel hole over the hood hole, the screw orientation is an X pattern if your standing in front of the hood
