Scarebird has one plate and another welded on top of it, also both plates are held together by the mounting bolts, there's no problem with that. I just did a price check, Rock Auto delivered to my door the rotors and calipers come to $106.06 and include pads.
It'll final out at a little less than $300.
Nothing against ECI, that guy is a real engineer, but you have to ask what you're getting for that extra $325.00. I guess you do end up with shiny hubs and new bearings and seals. The new bearings and seals shouldn't run more than $40 on the Rock.
R.
