Assuming I can chop saw cut a section out of each side/square up the cut pieces/weld em so both end flanges are parallel, would this suffice or do I need to bite the bullet & send it all in to Moser. I'd sure like to avoid the ~3 bills that will set me back .. Online threads refer to the locating mandrel shaft with the locating bushings on each end to locate the housing pieces before welding them & talk about out of round in thousands. If I get the end flanges parallel wouldn't I be OK? Your thoughts please. thank you for your time.
I did it this way 25 years ago. The axle is still in my Road Runner today. Thousands of street miles, hundreds of passes. Never an issue.
Doug
