Re: How to remove spray on bed liner?
[Re: redraptor]
#1599922
04/02/14 02:51 PM
04/02/14 02:51 PM
Posts: 28,312 Cincinnati, Ohio
Challenger 1
Cincinnati, Ohio
have access to a steam jenny? if you had a real steam cleaner, with high pressure, i bet it would peel off, in sheets.
Depends on type of liner and prep work done. The professional shop stuff should not come off at all, that's what you paid for. The DIY stuff and a lazy azz who slathered on a gallon, maybe. Like Scratch said, possibly identify what you have and recoat it.
I can tell you have never used a steam pressure washer.
Mine can blast mortor out of brick walls...it'll remove any kind of coating with the right tip and temperature.
I have been using 3 different steam pressure washer since 1983. I wore one out and replaced it and now have one at work and at home.
This is one of if not the most valuable and useful tools I own. It get's used for many cleaning and stripping jobs. It'll remove truck bed liner I promise better and faster than anything else including sand blasting.
