If I am interpreting correctly your diff is pointing 4.5 degrees downward toward the u-joint.
Thats a wrong interpretation, The diff is pointing down 4.5 degrees from parallel measured by a angle finder thats based off of a parallel plane.
What I mean is the nose is lower than the axle tube, correct? Parallel to the ground correct?
