Re: Main bearings for Big Block
[Re: CompWedgeEngines]
#1597691
03/24/14 01:43 PM
03/24/14 01:43 PM
Posts: 2,653 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Yes, if its still a Mopar rod journal, you'll need a Clvite CB527HND001. You can also try some coated bearing, which reduce the vertical clearance as well, but coating are really meant to be sacrificial over time, and the clearance will increase. If its a motr that gets freshened often, maybe not so bad. I would think though, the first bearing will do it.
Thanks, I think I found some of the Clevites.
2011 Drag Pak Challenger
