So, I've taken the cell apart several times, replaced the white gaskets and tightened it to what I feel is tight. I'm afraid if I go too tight I will crack the gasket. But no matter what I've tried it still has a very, very slow leak. Has anyone else had this issue? Do you have any ideas for a fix that will work, short of buying an aluminum cell with welded bungs, that's my last resort...
I've never had that problem with the 2 Jaz cells I have used.
It sounds like something is worn?
I would recommend a good pipe dope. Dope will seal fuel. Good luck.
I'll try cranking it down one more time like Rick suggested,if that still doesn't work I'll try the pipe dope.
Thanks for the suggestions
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
