it is erratic firing from the coil wire.It sparks when just beginning to crank and when you let go of the key and the sparks are very erratic in between,no distinct pattern.It may spark 3 times a 1 second apart then not spark again for another 4 seconds.
Should of mentioned this in the first post.
Your problem is an erractic spark, might be the coil wire. OR a bad electrical connection.
They say there are no such thing as a stupid question.
They say there is always the exception that proves the rule.
Don't be the exception.
