my AFR meter reads 14. to 14.8 at cruz if i give it a little gas it will read about 12.to 13 till it levels out and you still feel the slight vibe at the richer AFR.
You should be fine there..... lets go back to the
beginning of the build ... is the engine balanced,
what balancer, is it a stick or auto, if auto what
flex plate... give us a little info
