Iam reassembling my 383 had heads plained ( not very much) rockers seem to be very tight on valves when valves are closed stock shaft and rockers, rockers are riding valve tips ok. push rods are tight on closed vales. Should I install shims and how much? Push rods should be able to turn on a closed valve? Thanks Bob
