I bought the original key cutter from my Chrysler dealership years ago. There is a a number on the ignition that you can cut a key by.You have to have my book and cutter. Not sure about the doors. Not sure if you can see the number on a b body still in the switch housing or not. I don't think you can.
If you have the book and the cutter, can you cut keys? Maybe you can help Dave... but I don't think you can release the ignition lock from the switch housing without a key. You can't push the retainer pin in unless you turn the key. You have to get the code off a door lock. The key cutter person really needs a lock to test the key because just cutting it from the code is not foolproof.
