I don't see it as possible. The tires for one, won't hook up that well. As an example, I have an 06 GT mustang, Saleen blower with 7psi boost making about 480 at the crank. The weights would be close, your car to mine. The Mustang only pulled a 2.00 60 ft, went 12.42 at 115 mph. Most 7 psi blown mustangs like mine put out about 470 to 480 hp at the crank, 420 at the tires.
