I was at mopars at Englishtown several moths ago and made a couple of passes. I red lighted on the first pass then on the second pass ran alone and my time slip showed 11.70 at 114mph. Car number and lane number are correct. I just finished this car so it was the first time at the track. My car is a 70 cuda 4speed Dana with 3:54 gears. BF Goodrich T/A on 15x7 ralleys. Engine was rebuilt mostly stock 10.5-1 Pistons, Mr Six-Pac Cam, Good valve job, TTI exhaust with manifolds. On the engine dyno it produced 426hp@ 5400 and 523ft lbs TQ at 2300rpm. Is 11.70 possible with those specs? Seems off to me. Did I have a great run? Or is it more likely that there was a mistake. Love to hear you thoughts. I plan to try again at Muscle Palooza in spring. John
No,You would be hard pressed with those tires to get into the 12's.
My wifes 360 4 speed Challenger makes similar power numbers. With T/As and a 3.55 it's been 13.20@107. With slicks and a 4.30 it's been 12.50@110.
Doug
