Low deck block limit for crank is 4.25 the whole reason for the raised cam block is to clear 5 in crank ! Low deck verse raised you can tell where the water pump mounts, low deck is almost even with the top of the water pump blocks on the block, raised block would be almost 3/4 in taller at the same spot ! :
