Quote: I don't have this car anymore but it was definitely low budget (less than $3000.00 into the car including tires) it was ugly and it ran pretty good. My 360 started as a .040 over Napa rebuilt short block. I took it apart to check everything. I had the block decked (deck .015 head 63cc., gasket .028, compression 10.51)reversed the cast dished pistons on the rods and put in good rod bolts and had the rods resized. I put in an old Manley cam that I had. 443 lift [Email]224@.050[/Email] I don't remember the lobe seperation but I think it was around 108. I used J heads pocket ported with 2.02 int. valves and 273 adj. rockers an LD340 intake with a 1" 4 hole spacer and a Vac. 750. For exhaust I used heddmen 1 5/8" headers, 3" exhaust with ultra flows ending at the axel. I used a 904 with a Dayco 2,400 stall converter and an 8 3/4 with 3.91's the slicks were 8"x 26"x 14". Suspension consisted of 6yl. bars and comp. eng. adj. shocks in the front and 002/003 superstock springs with Mopar perf. 50/50 xtra long shock in the rear. The car was a 70 Valiant 4 door it weighed 3,320 with me in it. With an electric water pump drive, 5/16" fuel line with holley mech. fuel pump and a homemade fresh air intake (dryer hose and a dual snorkle air cleaner)the best run was 11.96/113 but it typically went 0's and teen's in decent air at Atco and E-Town. Typical 60'was low 1.70's. With a looser converter maybe around 3,500 stall it probably would have gone 11.70's or 80's.
I've admired this car/combo before. I believe it to be the "Champion of Cheap". Extra style points for it being a 4-door!!
