thanks !!!!!!
Oops, 216 is max cooling , if you have standard cooling it's the 215 fan, if you have no build sheet or don't care use the 216, it will move more air
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
