Yes I realize that. Thats why I mentioned they were stock untouched. This way it was a true unbiased comparison. I also believe that I could have made a difference with a port match, but I was only comparing them in their "as is" states. We knew we'd be changing engines in that car, but I will do a port match on it in the next car and document the change.
RIP Monte Smith
Your work is a reflection of yourself, autograph it with quality.
WD for Diamond Pistons,Sidewinder cylinder heads, Wiseco, K1 rods and cranks,BAM lifters, Morel lifters, Molnar Technologies, Harland Sharp, Pro Gear, Cometic, King Engine Bearings and many others.
