Did a back to back test last fall between M1 Dominator and Victor with 4150 base and an adapter. Did two baselines then made the switch. Car was ( at that time) 71 Cuda,440,3100# and saw approx .070 difference ( better with Victor). I cant say that the Victor or the adapter made the difference. Both these intakes were bone stock untouched. I did think the Victor ran smoother however, but didnt equate to any giant ET. I suspect the extra velocity and plenum area made the biggest difference.
RIP Monte Smith
Your work is a reflection of yourself, autograph it with quality.
WD for Diamond Pistons,Sidewinder cylinder heads, Wiseco, K1 rods and cranks,BAM lifters, Morel lifters, Molnar Technologies, Harland Sharp, Pro Gear, Cometic, King Engine Bearings and many others.
