Re: Rings gap - 150 shot
[Re: dart_73_br]
#1566636
01/22/14 07:20 PM
01/22/14 07:20 PM
Posts: 3,420 Toronto
mshred
Toronto
Found in their hyper catalog...
street nitrous:
TOP ring factor = 0.008 > 3.94 x 0.008 = 0,0315" SECOND ring = 0.004 x bore > 0,0157"
I think thatīs it...
That number for the second ring seems too tight to me, even on motor.
I followed my ring manufacturers instructions when gapping mine for the nitrous, and it recommended a larger ring gap up top then for the second ring...Then I posted about my gaps on another board, and was told by a bunch that the second ring gap should be bigger then the first to allow the trapped gases to escape.
I would say gap them larger then you actually want to spray, because you are going to want more pill size after a while, and the larger gaps really shouldn't hurt anything...but seeing your running hypers, I wouldn't push them too much...I'd be more comfortable spraying cast then hyper pistons, but thats just me.
