When I welded mine in. I ran the front of the car up on ramps, then jacked the rear up and set it on stands, with the stands place under the rear end housing. This way the car is up in the air and you can work under it, but it is setting on the suspension, just as if it were sitting on the ground.
Hope that helps a little. I think some people are thinking that "on stands" means you have them placed under the unibody, with the suspension hanging.
Here is your answer.
