Re: CHALLENGER QTR GLASS
[Re: B1MAXX]
#1559291
01/05/14 03:02 PM
01/05/14 03:02 PM
Posts: 7,327 Toronto (YYZ) Ontario
YYZ
Is there a differance between the run of 1970 to 1974 e-body qtr glass. I noticed the glass itself seems to have more holes on the later glass. Bottom line is can a missing 1970 window assembly be replaced by any year? Thanks!
The quarter windows are interchangeable across all years, though the '70 has a slightly different metal channel & weatherstrip. That does not affect function, only appearance.
For door glass, '70-'71 has 11 holes below the beltline, '72-up only has 9. I'm not sure about the interchangeability, but suspect that the extra holes for '70-1 may have had to do with the availability of power windows.
For hardtops, the door glass is the same between Challenger & 'Cuda, only the quarter windows and backlite are different.
For convertibles, all glass is the same between 'Cuda & Challenger.
