Mine is an all aluminum 496 Indy Maxx block.On the dyno it made 974 hp @ 6500 on 10 pounds of boost...got it home jetted it down 2 sizes and changed to 10 percent over and it made 14 pounds of boost so it should be around 1100 hp. 4.25 gun drilled callies xl crank.
Oliver rods
4.31 Ross Pistons/8.2 compression
Indy Legend-1 CNC heads
Dick Landy Rockers
Bullet/Morris roller cam Intake .707/272@.050 Ex .684/280@.050
Comp lifters
Smith Bros push rods
Charlies pan with swinging pickup
Milidon pump and single line cover
Supercharger USA Teflon stripped 10-71
2 Quick Fuel 1050 dominators
Mezeire high volume water pump
PTC Spragless convertor
Before install......
In the car.....
