I used one like that in a 68 Dart
I just used a drive shaft with a slip yoke
worked good and bolted right in with a drive shaft change
dont know how right behind the rear seal is a roller bearing no way a slip yoke would slid in the tail housing unless you are talking about making a drive shaft with a slip joint like they use in a truck.
I think thats what he did if I read it correctly
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
