Ditch the Spacer and run a shorter air cleaner if needed. 5" is excessive.
Lose the spacer. Hope you don't end up in the same situation I was in a while back. Get a big new intake that makes more power way up top, but you lose so much lowend torque that it never runs worth a crap at the track.
