Mike,
AFAIK there is not way to perfectly restore the finish of a Ramcharger box. I believe that all the restorers paint it....which is OK but not original.
If it were me I would look into cleaning it the best you could then possibly hitting it with 000 steel wool to remove any stains. Then followed up by semi gloss or flat clear. Thats how heater boxes seem to turn out the best. Paint distracts from the original appearance in my opinion. Ive never seen results from the full circle kit that Ive known of.
As far as any cracks you can mix paint with resin to hide the repair the best you can. Member Quikshift (I think thats correct) did one for his car with testors paint in the resin I believe. Memory is not what it was. haha
Keep us posted Mike, as I cant wait to see it when your done!!
Scott
70 Coronet RT 440+6
64 Dodge 330 - Future Hemi Clone
17 Challenger Hellcat - Green Go Driver
86 Buick T-Type Turbo V-6
