I have always found its easier to treat the leak from the inside from where the leak starts from instead of stopping the leak from the outside... thats why I use the stop leak... hasnt failed yet... once its stopped it hasnt come back even if you pull the bolt (but on big blocks I always use a high temp silicone) if I pull the bolts
