Is it a street car or drag car? I have mounted an alternator off the rear end before. Also, you should be able to still use the stock alternator mounts, but you either have to mill the water pump housing down to have the pulley's the same location as stock, or press the alternator pulley on at the location of the crank pulley and find a belt that will work.
JB Rhinehart, Realist
A-Body's RULE!
