Re: High compression, High Octane, and Boost??
[Re: 68Bullit]
#152714
11/29/08 10:14 AM
11/29/08 10:14 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Not enough dumb comments...yet
Brookeville, Md
I bet you do miss that car....for sure. If I'm currently at 400-415 horsepower, and then I add 6 lbs of boost, where would that put my crank horsepower, roughly????
BTW, here's an article I found on a 73 Charger with boost AND E-85. Guy says he would like to try something with the static compression of 10:1 or maybe more! Check it out....
http://www.carcraft.com/featuredvehicles/ccrp_0801_1973_dodge_charger/index.html
I was probably in the same boat the car ran 12.90 on cool days and 12.99-13.05 @ 103.5 on hot days before boost. It was a all steel 3850lb sled. After adding the S/C unit w/o tuning I ran consistantly between 12.08-12.18 @ 114. That was about 5.5-6lbs of boost. Mind you this was a 9:1 cast piston, stock 906 headed Summit 488 cammed 440. I bought an 8psi pulley but never ran it at the track Sold the car in the staging lanes Via cell phone. So I ran it all day thru the pipes, shifting at 5k around 4psi and the car ran 12.40's. I'd guess you'll pick up close to 100 hp and tons of torque.
Entire Thread
68Bullit
11/18/08 02:15 AM
jbc426
11/18/08 06:01 AM
68Bullit
11/18/08 12:57 PM
AdamR
11/18/08 01:29 PM
jbc426
11/18/08 04:24 PM
OzHemi
11/18/08 06:06 AM
DaytonaTurbo
11/18/08 07:12 AM
Mr440GSS
11/18/08 04:30 PM
68Bullit
11/18/08 05:47 PM
DaytonaTurbo
11/18/08 07:08 PM
Mr.Yuck
11/18/08 09:05 PM
68Bullit
11/21/08 03:51 AM
Mr.Yuck
11/21/08 01:51 PM
Mr.Yuck
11/21/08 01:52 PM
68Bullit
11/29/08 01:36 AM
Mr.Yuck
11/29/08 02:14 PM
Supercuda
11/29/08 02:28 PM
