You can always use a drop base if you have clearance issues.
Here is a list of intakes I know of that will clear the air box AND the hood on a 440 installed in a 70 B body ...
Stock Iron intake
ORIGINAL and DISCONTINUED M1 Dual plane ... current M1 Dual plane is a rebadged Ebrock RPM
Original style 6 pk intake
POSSIBLY the Ebrock performer 400 , NOT the RPM
and I'm sure there is an old offy with not much better than stock performance they MAY fit ...
ANYTHING else is going to require the air cleaner base to be modified .... A CH4B will have the air cleaner top hit the hood ...
As I was reading and scrolling down, I'm thinking; John knows so hopefully he'll chime in.
Wow factor, performance and ability to use a Ramcharger air box all point to the 6 pack manifold....
the M 1 is your best choice for a 4bbl, and the offy sucks (or doesn't...you know what I mean!)
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
