You can always use a drop base if you have clearance issues.
Here is a list of intakes I know of that will clear the air box AND the hood on a 440 installed in a 70 B body ...
Stock Iron intake
ORIGINAL and DISCONTINUED M1 Dual plane ... current M1 Dual plane is a rebadged Ebrock RPM
Original style 6 pk intake
POSSIBLY the Ebrock performer 400 , NOT the RPM
and I'm sure there is an old offy with not much better than stock performance they MAY fit ...
ANYTHING else is going to require the air cleaner base to be modified .... A CH4B will have the air cleaner top hit the hood ...
