if you just want to spend money you have an answer---if you want the best value on a new radiator--go to speedway and use the double pass aluminum----if you are economical (tight) i would find an aluminum replacement radiator in a 78-88 dodge truck and measure to see if it will fit---have run a $30 pickapart unit in my 64 plymouth for 7 years with no problems---just put a 24 inch speedway doublepass into my 64 tempest and it cooled the hot car just fine....bob
