On the back side of the Passenger side axle tube you will find a string of 6 numbers stamped into the tube. The first number will be 6 for a 60. Take the numbers to a differential shop that has all the Dana Spicer catalogs and look up the number. When a new version of the catalogs are printed, they drop the older listings so you will probably have to look at more than one catalog.
This.
The numbers are all you need. The Dana/Spicer catalogs DO NOT list axles by vehicle, they can't help you without the number.
Ed
